Steve Maskery
Well, maybe not throw it away completely, but certainly use it less!
I'm currently building a wardrobe, three big boxes sitting on a plinth. The carcases are made from oak-flavoured MDF with solid lipping, the base is solid oak. Everything has to fit together, of course. But there are lots of component parts – tops, sides bottoms, doors, long rails, short rails – the list goes on. I can't afford to make mistakes when measuring, and it is all too easy to get 89 and 68 mixed up, or 1010 with 1100, so I don't measure at all. So how do I get everything right?
The answer is to take all the measurements, not off a tape measure, but off a full-sized drawing. Here in the UK we call it a Rod. In the US they call it a Story Stick, but it's the same thing, a length of wood or a board with all the key dimensions marked on it.
This wardrobe is 1.9m wide and 2.1m tall, so I have piece of melamine board 2.4m long and about 250mm wide. All my horizontal dimensions are drawn out on one face. I need my tape measure for that, of course, and a selection of other marking out tools – square, rulers, eraser, pencil gauge, compasses, as well as the original paper drawing,
but when the rod is finished, I won't need to measure anything again.
I mark in my vertical sides, across the width of the board,
then draw in the height (along the board) of the plinth and dividing frame
Then I can draw in the thicknesses of the individual panels and cabinet bottoms, and clean up the extraneous lines.
The result is a full-size drawing of the lower part of the wardrobe assembly. I can see what it's going to look like and I can check that all the measurements are as they should be.
The other side of the melamine has all the vertical dimensions marked on it, from the floor right up to the top. It's useful to mark one end with a Datum mark, like this:
so that I mark from the correct end of the rod. This is particularly important if some of the dimensions are close to the centre - marking off from the wrong end could really spoil my day.
A second board has all the front-to-back dimensions drawn on it.
So once I have these Rods and I have checked that all the dimension are correct, and all the lines are correctly labelled, I can put away my tape measure and ruler. When I need to make a cut, I put the workpiece on top of the rod and mark off directly from the pencil line. It doesn't matter what the dimension is, it is “that much there”. I still have to be careful that I mark from the correct pencil line, of course, and that is particularly important if there are several lines close together, but at least it saves me from mixing up similar numbers, especially if I am using my tape measure upside down.
There are other advantages to using a rod, besides avoiding measuring errors. They can show up potential problems that would never show up on a paper drawing.
For example, when I drew up the smaller rod with the front-to-back dimensions on it, I saw that I had originally drawn up my design with the front of the base plinth flush with the front edges of the carcases. But when I drew in the doors as well, I could see that the front of the plinth was further back than it needed to be. As a wardrobe is relatively shallow, compared with its height, and this is going to be on adjustable feet, I could see full-size where the feet would end up. They are not very far apart and I need as much stability as possible. By bringing the plinth forward to be flush with the doors, rather than the carcases, I could get another 21mm or so of spread. It may not sound much, but every little bit helps and I would never have spotted that if I were working solely from an A4 drawing.
Another advantage is the ability to modify the design as the job progresses, if needs be. For example, when I have made all three cabinets and stand them together, I can check if they really are identical to the rod. If they are, great, but if cumulative cutting tolerances mean that there is a mm or two discrepancy, I can simply modify the rod to reflect reality, before moving on to the next stage.
So why not try making your next project with a rod rather than using your tape measure? You'll soon get the hang of it and it may save you making some very costly mistakes.
