Redfly
New member
Haya people.
Sorry my first post is a plea for help but I'm having trouble sourcing a short length of treaded dowel.
I'm building a work cabinet that has a small set of drawers that lift out of the top when a handle is turned.
Turning the handle also opens the doors. The doors and running gear are finished which leaves me with the lifting mechanism for the drawers.
I have tried a 16mm threaded nylon bar but the thread pitch means it needs to rotate sixty times to travel just 13mm. I have twenty turns available from the door action but by the time I gear it upto 60 I lose all power and the gears can't manage the umph.
I would like to replace the nylon threaded bar with a wooden screw (obviously with a much bigger thread pitch) so I can lift the drawer unit the 13mm in less turns. That way I can gear down a bit and give the screw a bit more umph ( can't spell torque)
So my question is, without spending a fortune on a lathe or an American tap and die set, how can I get my hands on a 200mm length of hardwood threaded dowel and a matching nut. Thickness isn't critical but it would be nice if it was around the 16-20mm to keep the modifications down.
Any ideas....
Any ideas....
