engineer one
hi there having just bought an LV No 6, and cleaned up and sorted the blade, i checked it with my engineers square. this was kind of scary, (not scary sharp)
generally one should only check square from one side, but i tested the flat surface from both sides, and found an anomaly. it was low on the same side of the square when on either side of the blade.
so my question is are the sides of the LV 2 3/8 blades parallel to each other and smooth when produced, or am i worrying too much??
paul
paul
