wwade":2snrmudd said:Go easy on pencil marks, go easy on filler, because the biggest pain for me has been the sanding at the end. On. the next project, I might sand the pieces as I go along.
Hot glue and then use a freeze spray to pop them apart. This may help: https://www.youtube.com/watch?v=9kyLY1xWrCIWizard9999":1svs1dh2 said:Pencils, yes learning that as well. But what was a real PITA in the last couple of days was when I wanted two identical brackets, I made one and then used double sided table to stick a roughly cut out second one to it so I could use a flush trim bit in the router to create an identical second bracket. The process worked brilliantly until I came to separate the two piece which was extremely tricky, I found it had to believe just how strong the bond created was. Then having separated them the remaining sticky goo left on both pieces was a real effort to remove.
I was using bog standard B&Q Diall branded double sided tape. Were my problems because there are better tapes for this job, due to using too much tape or is this just an inherent problem in this process?
Apologies if I have hijacked the thread, but it seemed to fit well as a beginner's lessons learnt.
Terry.
Wizard9999":3ldlrrz2 said:Pencils, yes learning that as well. But what was a real PITA in the last couple of days was when I wanted two identical brackets, I made one and then used double sided table to stick a roughly cut out second one to it so I could use a flush trim bit in the router to create an identical second bracket. The process worked brilliantly until I came to separate the two piece which was extremely tricky, I found it had to believe just how strong the bond created was. Then having separated them the remaining sticky goo left on both pieces was a real effort to remove.
Terry.
Wizard9999":1yvs6nyk said:The process worked brilliantly until I came to separate the two piece which was extremely tricky, I found it had to believe just how strong the bond created was.
phil.p":20oqi18s said:Did you get that one from Viz?
phil.p":3iakzzs5 said:Did you get that one from Viz?
