The piece is 25mm thick cherry, with a 7mm mortise needed. 70mm deep for a through-tenon. I have bevel edge chisels (Ray Iles) but it’s taking forever and I blew out the side of the mortise on a (thankfully) test piece.
I have a cheap Lidl pillar drill, I drilled halfway with a hss bit, but still the chiselling is slow and fussy. Should I:
1. Get a ¼” mortise chisel and continue by have with an appropriate tool
2. Get an end mill bit for the pillar drill and get as much as I can from both ends before going the chisel route
3. Get something like a two-flute cutter for my router table
4. Something else?
I have 20 of these to cut. Thanks.
4. Something else?
