wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
This was hidden within another jig thread but I thought it deserved updating and it's own dedicated thread. This means that it can be found easier and I can update it easier.
If any links are broken or pics are missing, please post in this thread.
Different way of cutting 45* frame
Cross-cut sled, different way to make it.
Shop vac modifications
Drill Stand modification
Drill press table improvement
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Cheap "Grip-it" clamp repair and improvement
Saw blade and router bit height guage
Cutting dado with hand router
Hand router bit height setting aid
Caliper (micrometer) modification
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Doweling with router table
Drilling shelf support holes
Magnifying glasses
Panel glue-up aids
Jointing with router
Doweling jig part 1
Doweling jig part 2
Feather roller for table saw
Push blocks
Feather roller - version II, prototype.
Straight edge on table saw
Feather roller, final version
TS fence memory
Dust free sanding
Amateur's working methods
Hold down roller for TS
Panel glue-up, overcoming cupping boards problem
Cutting strips on TS
CS cutting table
Saw blade cleaning with STP
ROS DC improvement
Router table fence distance and stops setting
CS (or router) Offset plate
CS with Zero clearance insert, why it's chipping?
T square
Measuring tape, not only for measuring
Measuring tape - version II
Construction Square - checking & adjusting to 90*
Blade cleaner
Triangles
Jointing with hand router II
Checking Diagonals
Checking Diagonals, version II
Checking Diagonals, version III
Checking diagonal, Version IV
Logs or round wood cutting jig
Router Lift for amateurs
Glue line on router table
Triangles
Amatorski Patentski
Sanding Paper everywhere
Screw clamps - long jaws
Drilling small hole over large hole or vice-versa
Even bigger triangle - "Copy" and "Past"
Tenoning jig for table saw - it's rolling...
Sharpening
New router - New table
All seasons crosscut sled for TS
Router table T-fence
Router table fence setting
Lo-tech TS blade alignment
Caliper modification
My first box (finger) joint
Rolling Mortise jig for router table
Router Lift
Rolling Mortise Jig - The test
Hold-down clamps for...everything (LARGE PHOTOS)
Cutting very small pieces on table saw
Do you have a Saw board (AKA - circular saw guide)
Crosscut Sled - my way
Knobs - easy, fast and cheap
Drill Press - holding wheels (knobs) and small parts
Fence stops (yes yes, easy, fast and cheap)
Circular Saw Guide
Shop-vac "filter"...always clean...
Thin boards glue-up
push block
Folding adjustable height table
Cutting 2 mm strips on table saw
Hold-down clamps - simple, fast and cheap...
Well done Niki!
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Magnifying glasses
Panel glue-up aids
Doweling jig part 1
Doweling jig part 2
Push blocks
TS fence memory
Dust free sanding
CS cutting table
ROS DC improvement
T square
Blade cleaner
Triangles
Checking Diagonals
Triangles
Amatorski Patentski
Sharpening
Router Lift
Circular Saw Guide
Thin boards glue-up
push block
Well done Niki!
