Just a wonder of nature, Spalted Beech.nev":2tcci4q0 said:chas, have you somehow managed to join two separate pieces of timber with a wibbledy line for the base or is it just a wonder of nature?
philb88":1ei4njkl said:That first splated bowl is a stunner!
Only an hours work, very impressive! Was it an already dried piece, or turned green (well as green as spalted wood gets!)
Alli":18v4e2y9 said:...... may I ask how you shape the curved sections that make up the lid? ..
CHJ":nczcqtk6 said:Alli":nczcqtk6 said:...... may I ask how you shape the curved sections that make up the lid? ..
Bandsaw and sanded, this is the way to do it well most of it :lol: just a couple of simple jigs for the sanding.
Picked it up a couple of years ago at one of the warwickshire shows, not my favorite wood to work being rather on the soft side but thought the figure was worth the effort. Have enough for another piece in similar vein.Paul.J":3enztm3o said:.......Can't say that i've seen Burr Tulipwood before??
I know of one piece now in Germany that has some character wood in the segments that is coming back for treatment, the joins are fine but the wood itself has failed, should look OK when it's been filled and cleaned up. Wood was obviously higher moisture content than I realised. Tried to bring it back xmas but was told it was too useful and would have to wait until UK summer visitors brought it with them.Paul.J":3enztm3o said:.......Are you finding any shrinkage problems with these pieces you are doing??
CHJ":sc58tzoi said:An hours worth of playing with yet more rotten wood.
Spalted Beech, 195mm dia.
I cheat and use Asley Iles beading tools Paul.paulm":1dagh72i said:[......the ring on the foot of this piece, .... Do you make it like a normal bead as you would in spindle turning, or use a shaped scraper ? Do you get much tearing or breakout or crumbling on the end grain areas of the bead or does it just depend on the timber ?
Shame if you haven't got a 125mm chuck, that extra travel turns a useful but often frustrating tool into a pleasurable go-to tool of choice for me.paulm":1dagh72i said:.....Was going to get an axi goliath chuck for that because of the extra range of movement of the jaws,
I have some made from stacked thicknesses of old kitchen chopping board. Biggest problem if turning freehand is getting them all the same diameter. The Axi ones are a very soft rubber on an Ali. core, getting close to needing some replacements but the high price has been putting replacement off. If your chuck only has standard travel then might be useful to make up some studs half a pitch bigger diameter, then some of the frustrations of finding yourself in between standard stud spacing can be overcome.paulm":1dagh72i said:......Could do with swapping the rather hard and squarish profile plastic holding blocks on the cole jaws for some slightly softer round ones like yours which I think would be less likely to mark softer timbers. Wonder if I could make some up from old plastic wine corks ?
