woodbrains
Jacob":1h0m5o8v said:Alan Peters is reputed to have only used a no 7. That's a daft idea too!
Hi,
Not reputed, said and wrote in his own words that he did. His furniture, being held in high regard as it is, contradicts entirely that it is a daft idea. It really rather proves that it might be something worth at least giving a try before dismissing as daft.
Wouldn't a No 5 1/2 be something akin to the size and at least aproaching the heft of a Norris panel plane, a super smoother of sorts? Of course it is not a law that a 5 1/2 or even a 7 should be used as a smoother, but it is not to be dismissed, either, if it works and is a personal preference.
Jacob":1h0m5o8v said:Except you are likely to get new areas of tear-out if you attempt to smooth the whole of a surface, which is why you want a small plane to enable you to get at small areas of tear-out. Bin there dunnit - and got the belt sander out!
If your plane is truly sharp and well set up for the task, why would you be any more likely to get new areas of tearout, because the sole is longer? If there is tear free areas from the thicknesser, these will not be likely to tear from the hand plane. so why not level the whole surface with a long plane, deal with the tearout there is and not create localised hollows.
Resorting to the belt sander is evidence that the plane used is NOT likely to be sharp and well set up for the task, however.
Mike.
