The Skew
Wish I could get him to teach me, that's probably the most useful video on turning I've seen. I'm getting catches often, going to go and practice all those now.
Allan Batty video + this Raffan one where he deliberately gets catches to show how, https://www.youtube.com/watch?v=jOvF5f1phhY inspired me to try some tests.
I've tended to avoid the skew for anything other than planing on the round, ie no beads etc, and I've avoided beads completely really as got a few catches on spindle gauge too.
I've gone the way of many american youtubers, who whilst excellent woodworkers generally, work on the lathe with a flat skew scraping and work the point into corners etc to make the shape in profile as it were. No catches, rough surface, then sand.
Anyway, I tried again after watching the two above videos, and although I watched many others, read the books, understood the theory, actually seeing someone do it and explain it so clearly got me here:
Every cut done on the Allan Batty video, not one catch, not a single one.
Feeling rather chuffed I must say.
Gary Rance demos at our club and he's good
The fundamental truth about the skew is you need two things. The right theory, which all 3 pro turners mentioned in this thread are excellent sources for but also practice. Many many hours of practice
And so you should be, young man!! Really good work. I'm going to have a look at those videos mesen' now. Thanks for showing your results.
You must be very old! :wink:
The hardest one was the large round on the square section (third from left if you include the chamfer on the end).
It's easy to dig in as the square corner comes around and get a large catch. This wood is 2x2, I did start that one on a 3x3 and got quite a few catches due to the extra size. So I started again with 2x2 as per the video, just to make all things equal.
Rhossydd":27iixj17 said:
Woodchips2":27iixj17 said:
Here's another demo of the skew by Gary Rance http://www.garyrance.co.uk/skews/demons ... odturning/.
To be pedantic, that isn't actually a skew chisel at all. It's ground cutting face is perpendicular to the shaft, so more accurately it should be described as a round beading and parting tool IMHO.
It is a skew, Gary uses a 2 degree angle which isn't a lot but in Gary's hands it does the trick and at a rate of knots (hammer) . I made a round skew and ground a steeper angle which suited my amateur turning but time was not a priority for me whereas Gary is doing it for a living. :lol:
Regards Keith
