My garage workshop has a steel up and over door fitted , and as its winter I am loosing heat through it , I have already insulated all the walls and roof so it was time to get a door ,
Yikes :shock: £1000 , or find a way of doing it myself
Here is what I had done
The door
The door has a folded edge to give it some strength and a basic frame to hold it together
I used the edge to fix 3/4" thick polystyrene boards , had to cut a rebate so they slotted in , only at the top and bottom of the door
Started infilling section by section
worked my way across til it was all fitted , some panels were held in place with some industrial adhesive I had left over from a job in the house
I also had to deal with a big gap / wind tunnel :roll: under the door , so
out with the damp proof membrane
and fixed it the the bottom of the first 8ft xx 4ft sheet of 6mm ply
Then on to fixing it to the inside of the door
I lined everything up and put in two fixing screws and penny washers just to hold it in place for marking out the remaining fixing points , I could not mark these out before fixing so used my chalk line , marked the garage floor on the outer points and I could see the ribs at the top so just pinged a line drilled the holes and fixed all the screws and washers
The lower section is now fixed ,
tomorrow the upper section and then some sealant around the door frame on the outside , a few draft excluder strips
and hopefully , the jobs s gooden :ho2
total cost , no more than £80 all in
Hope this may help other with this type of door
Allen
The door
Allen
