Well, I got a chance to cut out all of my sheets today and build two of them up before I had a dinner obligation.
When I returned, I decided to plane one side of the smallest piece I have (sits atop an 18" cabinet on an end). I was only joking when I said that you can plane it, and had already bought a bearing bit for my router. However, after working to cut all of the sheets (quite heavy for a one-man setup - and the kids have littered my shop/garage with their riding vehicles), and gluing them, I decided to plane one edge tonight to see the quality of the seam.
Planing is so easy that I think I'm just going to plane all of it, and spokeshave the sink cutout (and then sand the inside bits). It planes beautifully (though it's hard on the plane iron edge, I sharpened three times to knock all of the glue off of this and my rather unevenly sized strips), and there is no stench in the air of burnt plastic like you get when you cut, rout or sand it.
With three sharpenings, the total time to plane the sides into dead squareness was 15 minutes. Almost nothing at all.
Not a fan of the pattern - everything always looks different in a countertop than it does in a sample, but I have a theory about kitchens. If you don't like what it looks like, you'll get used to it after you see it a dozen times.
https://s22.postimg.cc/csejvcdxd/20180528_151928.jpg
https://s22.postimg.cc/nt9ozuivl/20180528_151946.jpg
https://s22.postimg.cc/y3c3z1ygh/20180528_204059.jpg
https://s22.postimg.cc/hfklwkyk1/20180528_205709.jpg
https://s22.postimg.cc/t4olkj2dd/20180528_205754.jpg
I will rout a 1/8th radius roundover on it, though. It's sharp in its current state, to say the least. The corners would end up being deposits of kid DNA.
(the stanley 4 in this picture did the planing. Flatness isn't a concern because the top layer is already cut to final size with a track saw, and marked with a 24" starrett...it's pretty good as it is. One line of green marker on the top corner and once it's square, the first stroke that removes the green marker is the last one).
