The Parkside pillar drill is it worth having?
kevan
New member
8 Dec 2020
UK
I am looking for a bench top pillar drill that will drill through 2.5 inch timber any suggestions?
The Aldi/Lidl pillar drills seem OK to me - I've certainly drilled through that thickness with mine (obviously stopping and removing drill from the workpiece to clear the shavings fairly frequently) - in fact I just remembered that I drilled through a 4" block of wood the other day with a 1" bit .... for a base for a Christma decoration my wife ws making.
I had a diddy Nutool bench drill press. Didn't drill that depth but certainly drilled 42mm holes with a forstner bit into all kinds of hardwood for up to 30mm.
Problem with most small drill presses are that the travel is only 50mm or so.
Thanks for this looks like it might be my Christmas presy after all
Kevan
