In a simmilar vein to the carboot threads; I went to a party recently and someone, in their intoxicated widsom suggested [slurring somewhat] that everyone should whip out their smartphones and make an ebay bid on something for 99p... I chose to bid on a number of items and here they are... Thank-you random drunkard!
From left to right: James Howarth Mitre Plane (for that item only, I increased my bid later and paid about £20 in the end), Stanley 13-050 scarcely used but a tad rusty and missing most of the bead cutters, a set of five Footprint firmer chisels (1/8" to 1/2") and footprint augers (No.8 and 1")
The mitre plane has had some hammer over the years (literally looking at the heel of it), but the makers mark is still very clear.
I was also shocked at how wide the mouth is; but upon testing it, it still performed very well smoothing end-grain on some scrap russian redwood, not quite glassy, but clean and well defined... the chip breaker is fitted extremely tight to the bevel, and the iron is still bedded perfectly, which probably explains it. It may interest some (and dismay many more) to note that the iron has been sharpened with a convex bevel as is the bent of a certain forumite; certainly works very well like that.
Either way, it's far better than using my jointer or a bailey plane.
The Chisels were not really a neccessary purchase (though I did lack a 1/8", and 99p for that alone would have been worthwhile, the other 4 are just bonus prizes!), but I have a soft-spot for footprint tools, so I'm pretty happy with them, all but the 6mm (mix of metric and imperial) which is chipped still had a sharp edge on them, but clearly haven't been touched in a long while.
The 13-050 is complete, in good nic other than spots of surface rust and works very well, I find the design is actually quite an elegant technical solution and easy to work with... not pretty though.
The irons were rusty but still sharp... i think the nicker's need touching up, but it still cut cleanly and fairly easily in this state.
The augers, are both pretty sharp still, clearly not seen a lot of use but been stored well; they're an awful lot better than the modern SDS-compatible augers I briefly owned before.
All in all, a pretty good haul.
