The Chair - Towards the Round
When it comes time to glue the parts together I thought that I would use West Systems epoxy (because it is gap filling) and mix in a little colour to disguise any gaps that may be present in the finger join. I have saved up sawdust from sanding the legs, however I think that this will turn out darker than the surrounding wood. Any thoughts and suggestions?
Regards from Perth
Derek
Hi Derek
Once you get the finish on it should hardly show, probably best to do a test joint with some finish applied to be sure.
What finish are you going to use?
Excellent to see this work and the progress. I shall follow this with interest knowing it's going to be very good work, but also because I've been planning a chair with no straight lines anywhere and I need a few tricks!
In my experience West with sawdust is considerably darker than the original wood. You should get a better match using their 207 clear hardener but as Pete said do some testing first.
Graham
