Routermonster
Hi all
Inspired by the sharpening posts on this forum I decided to give my neglected and abused 20 year old Tyzack dovetail saw some TLC. So I cleaned it up and sharpened the teeth in a rip pattern. it's not perfect (20 tpi are difficult to focus on!), but it cuts now!
Anyway, one thing led to another and I thought I'd buy some tenon saws off ebay, thinking I'd practice my sharpening skills (?) some more. I ended up with this Wm Hargreaves saw:
.... and here's another view:
The blade and handle have been coated in blackish gunge (some sort of wax?), so I'm inclined to clean it all off , get rid of the rust on the blade and see whether I can remove the remaining varnish and polish the handle. I've tried to undo the clench screws, but they're locked solid and look like they'll be impossible to remove without damaging them.
The handle wobbles a little, so if I can't remove the screws, should I try to insert a small sliver of veneer in the slot behind the blade. It desperately needs jointing and sharpening; the tooth pitch is 16 tpi so it should be easier to sharpen than the DT saw.
Is it worth spending time and elbow grease on this one?
(I've got a couple of old 10" Tyzacks waiting to be done as well - SWMBO is not impressed!)
Les
Les
