tearout on unknown wood
mickthetree
24 Feb 2006
Tring - Herts
Hey all
In a last ditch attempt to get something in for my comp entry, I grabbed a board out of my stash today which might just do and got to work.
Its rough sawn, not sure what it is (another bit from a joinery firm liquidation) but it will do.
Used my number 5 to clean up the rough sawn surface at 45 degrees
Which worked fine.
Then set about flattening with my number 7
This was ok, but started to get a bit of what I think is chatter. Never had it before.
Used my 4 1/2 record smoother and that was even worse! On the finest of cuts it would all of a sudden dive into the wood.
anything I can do to over come this? I tried skewing the plane. Is a scrapper the only option? (dont own one) Dont think I have time for that.
Plan was to finish one face then re-saw it and get 2 or 3 boards out of it.
Might end up using some recycled wood for this comp entry now....
I'll probably be burned at the stake by handtool purists but - belt sander with an 80G belt
by the way that wood looks like mahog or sapele or something similar so do be careful of the dust - they fall into the same category as iroko for causing you harm by inhalation
Maybe not a belt sander :sick: But there's no shame in using a ROS to eradicate tear-out. Let's not be snobs now [-X
I've got a load of that stuff in it's different flavours. Sometimes I can get it ok when sending it through the thicknesser by taking tiny shavings and flipping it round the other way. The grain seems to go back and forth quite a lot.
hmmm
Think I might put this one back on the shelf and use some of this recycled wood for my comp entry. No time for messing about. Times getting tight!!
Got a belt sander, but no ROS.
Heres a close up of the grain (when it behaves)
cheers for the suggestions chaps
wizer":32tuvy83 said:
Maybe not a belt sander :sick: .
actually i only use the belt sander for finishing - my main weapon on obstinate woods is the performance power power planer - then i follow up with my ryobi belt sander with 40G then 80G - and move to the ROS for 120 and 240
Try using a back bevel on your plane iron to raise the effective pitch, or hone a micro bevel on a bevel up plane to raise effective pitch. David Charlesworth explains this in his latest DVD, I tried it and it works brilliantly.
Kind regards, Mark w
A belt sander or ROS is great for getting rid of the tearout.
They're just hopeless at keeping a board flat.
Karl
Hi,
Scraper, either by hand or in a scraper plane.
Hello,
I've got very limited experience with hand planes, but that wood look's a lot like aphselia doussie. I've been working on a big project with aphselia and have the exact same problems like you. Planing goes perfectly and suddenly BAM huge tearout. The blade also looses it's edge very quickly.
I have added a 15° back bevel and this has helped a lot with the tear out, but still have occasional tear out without any visible (grain direction) reason.
Have you found a yellow (sulfur coloured) powdery residue on the wood, if you did it's surely aphselia.
Looks like sapele or something similar, the problem you have is interlocked grain, the vertical stripes you can see. You need a well set up smoother or scraper for this
Yeah, looks like Sapele or one of the mahogany types. You're getting the tearout because the grain goes in opposite directions as you move across the board - its why the grain seems to flash and change as you move around the board.
To stop tear-out you need a very sharp blade, a fine cut and a tight mouth when using a plane. You'll still get areas that seem immune to this approach - thats when a scraper saves the day. You'll also find that planing from one direction gives the least tear-out - try planing from different directions to see which is best.
As mentioned, power sanding will smooth things out without tearout, but you won't end up with a flat surface - something that will become painfully visible when a shiny finish is applied.
Hope this helps
Philly :D
...and only 12 days to go! :lol: :lol:
Seriously, the grain as Philly and others have said is 'interlocked' or 'rowed' and will only be really smoothed with a scraper or back bevelled iron. A ROS will do the job but the price paid is that the surface isn't flat - Rob
Does your belt sander have a frame? - makes a BIG difference. I use a frame the size of 3 No. 6 planes side by side - it yields a very flat surface (dont like the noise & dust though) Uneven scraping can give a scalloped surface too .
Matt
Hi Matt
No, no frame unfortunately.
I've put this piece back on the shelf for now. For when I've got some more free time. :D
10 days now is it Rob? ::Gulp::
