I'm fitting a tail vice to the new workbench.
This should have been designed into the original lamination but I didn't do this so have to retrofit!
The end cap is removable.
I wondered if I could use dowel rod as the guide / retaining rail for the travelling block as I thought putting forster holes in might be easier than forming grooves. There'll also be a step in the channel to support the block so it wouldn't be relying solely on the dowels.
Such as in this diagram attached. Would be 20mm dowel.
Would welcome thoughts on this?
