transatlantic
Boom!
I've noticed that I'm not getting straight cuts when ripping pieces through my table saw. When I place a straight edge against the sawn edge, it touches on either end, but then has a shallow curved gap between the two ends, about 0.5mm at it's largest in the middle.
I'm guessing this is either to do with my fence, or more likely my technqiue, but I can't think of a case which would produce this kind of geometry?
I should point out that it has happened on mosts cut I make with varying material (pine, ply, mdf), so pretty sure it's not to do with the material.
