Table saw blade ?
Tonyhaz
2 Mar 2017
Essex
Hi, is it possible to cut metal with a table saw, ?
I have a small Clarke table saw and wanted to know if there's a blade that cuts metal easy,
what type of metal do you want to cut?
I just cut a zero blade insert in aluminium on my table saw, but I don't hold out much hope for the blade after doing it, cheap blade supplied with the saw. Whilst I was at it, I put a close tooth purpose designed hacksaw blade in my Bandsaw, this has worked perfectly on sheet metal (riving knife) and aluminium (zero insert), get in touch with Tuffsaws they have them available on line.
Mike
