Table saw blade for cutting laminate?
Co1
8 Mar 2018
Yorkshire
Afternoon all. Can anyone recommend me a table saw blade for cutting decorative end panels on a kitchen? Need minimal tear out obviously and I can’t do it with the track saw as it’s an angle piece.
Col
Will your track saw not cant over for an angle cut?
If I cut "laminate" on my table saw I use a 48 tooth TCT blade, and place a sacrificial plywood bed on the saw table top to act as a zero clearance.
I also have a 60 T triple chip bade, but don't really use it as I get as good a result using the 48 T blade.
Thanks Hoj, but it’s not the cut that’s angled, the piece of trim itself is a 90 degree corner section, so when I said angle, I meant like angle iron! There is only 75mm or so of flat surface for the track to sit on.
