Lord Nibbo
No finish applied as yet.
Quite an interesting project, no visible power cable going to the lamp holder.
The legs all look solid walnut, it tested me doing the glue up as the electrics had to be routed through the wood before the glue up.
Two coats of Danish oil
Here's another I did earlier
Made totally from scrap offcuts of American black walnut & beech, not quite finished just the lamp holder & wiring to do
The lower part has four pieces on the two faces that are in view, in all it took seven pieces to make up a hollow box section. The top shorter part was done in two pieces with the centre routered out before I stuck them together.
The beech part was all one piece, with a tennon top and bottom, then a mortice was cut all the way though it, like in this pic
It was all glued together except the base wasn't fitted then it was passed over my planer on two faces before sizing it through my thicknesser. The top beech cap was fitted the same way but I have to drill it to fit a brass pipe to carry the lamp holder. When I've got the bits I'll post a pic of it finished.
It's going in this room but I'm only testing it, SWMBO will decide where it goes
PS.... EDIT... The Yucca(?) in the corner would anyone like it for free? you will have to collect it though
