I have made a dining table, approx 6' x 3'. There is a full width drawer each end. The mortices were nice and tight but I suspect that the cross rails have too small a cross section because it is raking quite badly. These go below the drawer and so are only about 2 x 1 (the 1" is the height, making it worse). The top is finished but not fitted, This cross rail at each end is the only thing at the moment connecting the 2 long sides of the table to make the frame.
I suspect that I should have made letterbox type drawer openings, but the drawers are made and finished. in fact, it is otherwise all done bar drawer pulls and top fitting. The legs are not moving on the floor, and the joint itself doesnt appear to be moving, however it must be. Left to right is a large haunched and drawbored mortice and tenon, so no racking in that direction.
Does anybody have any suggestions as to fixes?There is the possibility of putting a central (or 2 just off centre) cross rails in as deep as the aprons, but clamping a baton across hasnt make much difference that I can see. i know that the top may firm it up a bit but that has to be free to expand and contract.
