Sweet smelling clock
Dalboy
18 Sep 2008
Canterbury United Kingdom
Thought I would get in the shed and turn a couple of things.
First a perfume atomiser made from European Oak and finished with CA/BLO
A Clock made from Sapele and found some clock bits in a box of turning bits. This was made with the help from my grandson who did a little turning all the sanding and polishing. This was his design (I think he made it up as he went along)
I was just about to post a question.... and would you believe it there's a picture of what i was about to ask about......
I too have made a perfume atomiser (from a kit), from memory it required a 15mm drill bit..? I've got a 14mm and a 16mm... but not 15.
So i drilled out at 14mm and sort of wiggled the drill and did a bit of filing out too. Eventually got a hole the (right?) size i needed.
Next problem was then 'truing' up the ends. I've got a set of 4 barrel trimmers, but the largest is only 10mm. What might appear to be a silly question.... but how do/did you go about trimming the ends up..?
This is also true of some of the larger more exotic pen kits i've seen, they require a 12 or even sometimes a 14mm drill bit for the brass tubes. How do you go about trimming them up..?
Nick
Hi Nick
First of all I take a scrape piece of wood and drill a hole (the same size as the smallest barrel trimmer 7mm I think). Then mount this on my pen mandrel turn the out side to the same diameter as the inside diameter of the brass tube.
Mount the barrel trimmer in the lathe/drill press, put the wood into the prepared brass tube trim as normal using the insert as a guide.
Hope this is clear will photograph the insert and bushings if you want
The insert for trimming can be made of other material if you want it for pens, but remember it is best to use a soft material so not to blunt the trimmer.
JT
the grandson had a great time, I lined the sand paper up so that he could work through the grits. Good job he only visits occasionally otherwise I would lose the workshop
