RobinBHM":14gk7942 said:
Ive always wondered how come when running a longish cable down to a shed there is alway the concern about voltage drop and yet the domestic supply into a house isnt tree trunk sized. Surely houses arent all the same distance from a transformer.
Also is it true that domestic supplies are thress phase with single phases going alternately down the street.
£15k def sounds better thsn £62k!
I have a feeling 120 sq mm cable is not very flexible and I guess itll need more than a pair of screwfix side cutters to terminate.
It's to do with the shear volume we are sending out into the street.
Most low voltage mains (well in my area at least) are protected by 250-400A fuses each phase. Add that to the size of the mains, somewhere between 70mm and 300mm conductors and you've got a very capable system. Then also factor in most substations are within 500-1000 metres of each other and they're running at 11Kv obviously dropping down via the transformer to 415/240.
To be honest we have more trouble trying to get the voltage lower to the 230v spec we've agreed to adopt. I've lost count of the times I've changed the tappings on transformers.
Most new supply cable is a concentric 16-35mm single phase, and again here, we look at approx 40 metres maximum run for the service/supply to the property
I forget the rules and regs on LV these days, I concentrate on 11Kv and above, but it's still a fairly simple set up.
The mains in the street is a three phase cable and at points along it's length the service joints are done, tapping off for the supplies to the houses. At each joint we try and balance the load by connecting the houses one to red, one to yellow, one to blue. This is repeated until all the houses are serviced.
Planning engineers look at the required loading and size everything to suit. When I was still on the tools we were left to choose the phasing ourselves, as long as it would end up fairly balanced. I believe today the jointers are given instructions on the job cards.
I just realised its brown black and grey these days for the phasing. Up in the bigger voltages we use 123 or abc.
Hacksaw and an adjustable spanner :lol:
No I joke, we have big core cutters that depend on strength of the individual. We still do use hacksaws and junior hacksaws, all insulated.
There's also hydraulic cable cutters, mine would cut a 400mm three core in about 1 minute in one go. There's always the Stihl saw for some of the biggest.
It's bloody heavy stuff though, we used to have little games. Who could bend a solid core 300 around their neck etc, :lol:
A few metres of some of the cables, and I'm talking 2 or 3 metres here, will have you on your knees in about 10 yards. On days when we had a load to lay we'd all muck in with the labourers, but would be praying for the JCB to turn up and drag it in. And in the cold weather.... forget about it. Waiting for the temperature to rise so we could get it laid or warming it up with a blow lamp as it comes off the drum. God I don't miss those days.
We cable jointers develop a good grip as well, seriously. You used to get one of my old bosses who wouldn't shake hands with any of us. My old mentor Clive"Jack hammer" Lewis had had hold of him years ago, broke three fingers apparently. Well so legend had it :lol:
I'm going to memory lane it a moment.
Back in the '90s when I was still working for a living I had a servicing job to do to at factory in Newport. A new 300mm three phase service was going in. Terminated in a 400A cutout. Mains straight joint onto a previously laid main cable.
Anyway on my way down we called into our local cafe for a breakfast. My labourers would already be on site getting the hole dug and the cable laid. Just about to walk in the cafe and the phone goes, "Al' don't rush down we can't get the cable in!" Okay's my answer, going for breakfast. After a good fry up we get own there, and it's blue murder down there.
My boys are ripping into the site agent, he's firing back into them. What the F is going on. Dai tells me they've been trying to push the cable up the fitted duct line into the building, but it's blocked. The agent is saying it isn't blocked. Okay, okay just "flush it" I say.
So Malcom fires up the hydrovane and we start to drag the hoses in. So with a few plastic bags we seal the top of the duct then poke the air hose in. Sure enough the duct blows clear, no blockage. See says the agent, it's clear. Right says I, lets get this EFFing cable up this pipe.
Jesus H Christ!! About 2 hours later and we've got nowhere. We can get in about 1.5 metres and that's the lot. So I'm off on one and go for a smoke. Well I take a little walk around the site and get talking to a few of the lads. "Having trouble round there mate?" says the one guy. "Aye you could say that" I say. The other guy pipes up "I told him three weeks ago those 6" 90 degree bends ain't no good for a duct". "Eh??????" says I. " yea mate he shoved a drain bend on that black ducting of yours".
Right. Round I go. Shout at the boys, "Pack it all up lads, get out of here". Smiles all round.
The agent comes over "where you going?"
"We're off mate". "Why?" So I let rip. "mate if you can get that ****ing cable up that duct, WITH A 90 DEGREE BEND ON IT, you're a better man than I gunga din". "well it needs a bend for it to come out of the floor". "Not a ****ing 90 it don't"
I could've quoted him the minimum bending radius for a 300 cable (300 is about 80-90mm diameter and made up of 3 solid core aluminium conductors), but I decided I wouldn't.
All I say is "I'm signing my job sheet with unable to complete and the reason why. There's the cable. You get in and give the office a ring".
Fortnight later the job card comes my way again, site ready. So down we go. There's the cable, ready for jointing outside. In we go, there's the cable sticking up from the floor surrounded with a brand spanking new patch of concrete all the way around it.
Along comes this guy. "Hi boys, I'm the new site agent" :lol:
Sorry about that.
Back to the point.
The connections these days are all mechanical, basically bolt on/clip on and tighten. I was taught in the days when we used to plumb/solder the cores together. A metal pot full of solder and a pair of ladles.
The cores would be clamped up in a weakback ferrule, fluxed and soldered together, all done while the cable was live. At HV we do turn it off :lol: , but we used to solder that as well.
We weld some of the bigger voltage joints, depends on spec and type of conductor.
For LV a lot of the connectors are of a pre-insulated design these days and lots of the insulation these days is heat shrink , but a self adhesive plastic patch wrapped up with Scotch tape is quite a common method of insulating a connection. It depends on the system being bought in and the make up of the cable, aluminium or copper etc.
There you go a brief history of supply cable jointing and construction, that was fun.
