SketchUp Guru
I learned a new trick this morning in SU.
I knew as do most of you that the Zoom Extents button
will set the view to show the entire model. The new thing is that Zoom Extents in the Context (right click) menu zooms to fill the frame with the selected geometry. This is handy when you want to edit a small part of the model. You can select it and immediately zoom into it.
