SU Dovetail mirroring problem
mahking51
15 Nov 2004
Nr Dorchester Dorset
Hi, One for Dave R I think!
I have made a simple DT box in SU using the component method but the DT's are NOT symetrical therefore when I copy a side and rotate it does not fit the other end.
Is there a way round this short of redrawing each end/side?
Regards,
Martin
Don't rotate it - mirror it!
Make a copy of the end detail..... use the scale tool... grip on the middle axis you want and drag it through itself.... type in -1. Then move it where you want it :)
All as just recently learnt from DaveRs tutorial in the 'FSUT dovetails' thread here. Unless I've totally misunderstood the question of course :)
Doh!
just realised what I was doing wrong, and I watched the video first as well!
Will tryy again and let you know how it goes.
Regards,
Martin
