stocked up again..
stevebuk
23 Jan 2007
Nottinghamshire
just come back from the wood yard and Bassingfiled stocked up with 1" thick pine ready for cutting the 100 items i have to cut for this chap, also have 20 names i need to cut for myself, hopefully will be around again in a while..
sounds good ive found out my timber yard does some pine it just under 1 inch about 22mm you have to buy it in 4.6 metre lengths anbout 11 inch wide and it works out at 46 pound not sure if that good or not but they are competitive on everthing else
mark
hi mark
just having lunch, where is your timber yard and is the pine good quailty, by that i mean the amount of knots in it, i can use the pine with knots so long as they are small tight ones and not the large ridged ones, as the chap that buys these shapes from me needs a flat surface..
hi steve im not sure about knots i only had a quick look its alan and ore in chesterfield the place where i get my timber from
mark
Hi Steve ,just had a look at your F/B WoW you have some great stuff on show .what an inspiration can't wait till tomorrow and try some of your designs ,hope you don't mind .They won't be anything like yours but I will try ,Love your work .
Not a problem Eugene cut what you like its all practise. Dont forget to show us how you got on and if you need any help give us a holla..
