GazPal
J_SAMa":v4d4wwgo said:Hi Gary,
Here's my current setup, please take a look and tell me how I can improve it :
180 grit sandpaper (which doesn't remove metal as quickly as I want it to :x )
1000/3000 combination waterstone for general sharpening
6000 and 12000 micro-mesh sandpaper for polishing
I was just about to place my order for the diamond paste. Maybe i could add something else to the order...
I guess it's not really because my sharpening setup is not good enough. It's something with my technique that's not allowing me to remove metal quickly on coarse sandpaper. IMO 180 grit should be quite coarse... Applying pressure to the corners only seem to round the corner off and I was still nowhere near the camber I wanted (10 inch in radius) after 20 minutes...
About oilstones... Well, IMHO waterstones are just as good as them so I don't think I'll need them for now
Thanks, I know I've been asking a lot of stupid questions
Sam
Hi Sam,
There's no such thing as a stupid question. I think you've got the aspect of edge honing covered by your 1000/3000 grit stone and needn't go any higher in grits apart from making yourself a strop and buying a stick of honing paste, but shaping/re-forming primary bevels is best done using courser stones and grinding wheels. Paper is fine for occasional use, but IMHO can cost far more in the long run than simply picking up a course 220 grit stone or courser. Water stones may well be just as good as oil stones and I don't dispute the pro's and con's involved in using either type, but you will find yourself replacing water stones far more frequently. Especially if trying to push their limitations by putting them to comparatively aggressive work. I still have and use oil stones I bought as an apprentice during the early 70's, which have sharpened and prepared more edges than I care to even try to remember and they're still going strong. I expect they'll also see quite a bit of use by my son and grandson when I'm dust and simply a memory.
Lacking a the use of a grinder I'd consider creating the camber and roughing-in the bevel using a flat file before refining the contour on stones.
It's all too easy for one to become overly focused on tools and sharpening instead of function and now is perhaps the time to concentrate on woodworking techniques using primary tools, rather than running ahead and buying a porsche before having enough fuel to put in the tank and learning how to start the engine. Keep it basic and you'll not go far wrong, plus save yourself money in the long term. :wink:
