Hi all,
I recently got my first and only two planes, the Record 04 smoothing plane and 05 jack (thanks to GazPal, who very kindly gave it to me
Well you've probably already sensed that I've never touched a plane before... So I'm kinda in need for a lot of help here...
I don't have any problems with the 04. It's a joy to use. The 05 was also fine... That was until I tried to take off large shavings with it...
I want to reduce the width of some 44x94 mm stock (just think of it as 2 by 4) because it came with all its edges pre-rounded :evil: I don't get why the hell that was done, but I wanted to laminate some stocks and these rounded edges are certainly unwanted. The only way to get rid of this that i can think of is reducing the stock's size.
Anyways, I adjusted the depth of cut on the 05 jack plane and went ahead to take large shavings off of the stock with it. I moved the plane at a 30 degree angle to the length of the stock. It planed smoothly but I couldn't maintain a consistent width either across the width or along the length... There was an 8 mm difference in thickness over about 1.5 m of stock, and that was after I straightened it (trust me, it was that bad). For across the width (94 mm), there was sort of a bevel of about 8 degrees. I know... It's terrible right...
But I guess this is what you get when there's no one to teach you in person.
It's obvious there something very wrong in my technique... so could someone help me find a video or book that thoroughly explains how to resize and straighten stocks with a jack plane? Or you can just give me a few tips and I'll try'em out.
Sam
