belfastrab
New member
Hi
First of all I am new so hello and I am looking forward to using the site.
I have just finished building my shed at least on the outside the inside has yet to be fitted out.
The shed is made with 3 x 1.5 inch framing and cladded with 1/4 inch thick shiplap weatherboarding. I wrapped the framing before adding the siding with breathable waterproof membrane stuff I had left over from a small job I done to my house. Shed size is 12ft x 8ft and 8ft high. The doors are double glazed mahogany and I have one 8ft x 4ft window. The roof is felted with very heavy duty wire felt (ex MOD stock)
The shed is literally just finished a friend called to get my off cuts for his fire and I unlocked the shed doors to give him the grand tour. Within seconds of entering the shed we both had severe eye stinging and I had a mild pain in my throat my friend didn't but I was deeper in the shed than he was. Within a minute of keeping the doors open and also opening the window whatever was causing the eye stinging and throat pain had passed. It happened again today and once again once I left the shed ventilated for a few minutes everything was ok. Both yesterday and today have been pretty warm and the shed wall that has the window in it get's the sun for most of the day (by design).
Could newly purchased wood that has been left baking in the sun cause eye stinging or throat irritation in a non ventilated space?
I know some treated timbers are not good to burn as they can give of dangerous gases when burnt.
Does anyone know if the wood is the culprit of this and if so will it go away eventually of it's own accord and if not would painting the wood on the inside of the shed help to seal the wood and stop whatever this unseen menace is.
Any help or advice would be great.
Rab
Rab
