Steve Maskery
This is my Tip Of The Day in 10 easy steps.
1. Take a Victorian table that used you be your grandparents'. Lets assume it's spent many years in a bay window getting bleached by the sun, had a few water marks from vases of flowers and a big ink stain from homework some time in the 1960s or 70s.
2. Strip off all the old shellac. Bleach out the ink with oxalic acid, realise it now has pale areas so bleach the whole lot.
3. As it now looks insipid, buy some potassium permanganate, because some other bar steward has the tub you already own.
4. Apply several washes until the mahogany looks rather wonderful again.
5 Apply many, many coats of shellac with a brush, to build up a body.
6. Denib with P600, apply many more coats, denib, more coats, denib.
7. Decide to paint the outside of your workshop, where the cempanels were jointed with filler, which is a bit rough and needs sanding. Switch your Abranet pad to 80 grit to try to sand the filler, doesn't touch it, it's like concrete. Go back to the table.
8. The table is looking good, so denib it to start polishing.
9. Look at the furrows of P80 and swear loudly.
10. Start again.
10. Start again.
