Philly
Hi All,
Well a little package was waiting for me yesterday.....
Forgot I had ordered this. Its a Purpleheart/Maple smoothing plane, blade bedded at 55 degrees. It comes with some test shavings still in the mouth of the plane.
As you can see it worked great straight out of the box.
The iron is really thick-6.5mm! The back was flattened and polished out near the cutting edge-very nice and saved me a lot of time! :shock: The plane has some clever little features. There is a throat insert out of Ipe which can be moved down and leveled to make sure the mouth is always tight. There are two grub screws either side of the mouth to centralise the blade. And a hardened insert on the back of the plane to save damaging the body when adjusting the blade.
After giving the blade a hone the plane really sang, cutting lovely shavings from this tricky mahogany. The higher blade angle deals with tricky grain no problem. The plane is quite hefty, and as I use a small Gordon smoother a lot, I found it a bit tiring to use for a long period. Guess I'll get used to that with a bit of practise though.
So do I recommend it? It surely is pretty with it's contrasting Purpleheart and curly Maple body. There are some clever features which show that a lot of thought has gone into the design. And it works really well straight out of the box-a rarity today!
Check out the web-site for more details (he will build one for you with whatever specs you desire!) http://www.knight-toolworks.com/
Oh and the cost-mine was $142 including postage from the States. Not bad really.....
Good thing I didn't win the Box competition-any more planes turning up on my door will probably cause the Missus to explode! :twisted:
regards
Philly
regards
Philly
