The question to ask is how many home workshops have exploded over the last twenty or thirty years due to ignition of an explosive atmosphere within the extraction system, I cannot find anything. If the pipes are flowing gas or a powder then you will be under ATEX regs and then it is not just the ducting / pipework you need to be concerned with but all electrical fittings as well. As for the bonding, Sporky is correct in that if there is a need for bonding then just relying on a push fit pipe is not good enough, if in any doubt then read the machinery directive and electrical guides on bonding and protective conductors. A good example here is that any panel on an electrical system that is designed to be detached or opened must have it's own bonding conductor, you cannot rely on hinges or the fasteners.
So let's just get on with woodworking and stop worrying about the what if's, you are probably at more risk from being hit by a frozen cowpat from an aircraft than your extraction system exploding.
I think I am in agreement with you. I am gonna set it up and then see how big an issue the static shocks are. Thanks all for the input.
