If you decide you'd like to make one instead you could make a template with some hardboard or something rigid enough to mark out from.
I suspect a rigid enough cardboard would work even.
On my 275 there was an old riving knife that was too thin and had lots of bends in it.
I put off working on the riving knife until I got my saw setup and working as I was expecting it to be a lot more difficult than it was, until I had it mounted.
This was because nearly all of the videos I'd seen on mounting one seemed a really flimbsy affair.
This is certainly not so on the TA 275
, It is rock solid and very simple design
I doubt the smaller startrite knife mounting design would be any different.
One thing I might consider when making another, is making the knife unable to dismount if loose
for some reason, from human error, because it is very rigid.
I just mindlessly copied the design that has its mounting slot with an open end to potientiently
fly out, instead of what I've heard which Steve has mentioned here before...
A knife that is captured, so you have to install it sideways, instead of just plunging down into the slot location and tightening up the bolts.
I have another chance to make one soon so I will go this route.
I dont have one to copy from this time around, nor is there any info on the saw on the web.
But I do have a blade for the saw
and that's the essential thing to make a template from.
Good luck
Tom
