Hi Folks,
I'm trying to overhaul a Startrite SD310 planer thicknesser which was acquired by my late father. Despite the cutting block having new bearings there is some play in the cutting block. This is coming from the spindle which goes through the centre of the cutting block cylinder.
Is this normal? There doesn't appear to be any way of adjusting this and I'm concerned this may cause damage to the machine when I eventually fire it up.
If anyone here has one of these, I'd be interested if there's any play in the cutting block which is not caused by loose bearings, but from the spindle shaft which goes through the middle of the block.
Many thanks
Matt
PS: I've uploaded a video which shows the block
Many thanks
Matt
