Hi Steve,
I have a 301 I bought s/hand a few years ago. OK for general cutting and very solid. It does lack power and struggles to rip green wood 6" deep.
One problem with mine is that although the fence itself is a solid lump of steel the angle to which it attaches is less so. Mine is bent, don't know how or why. However, freehand I can cut a pretty good straight line.
The table tilt adjustment is a bit primitive too. There are no screw adjusters for table or fence its a case of slacken the bolts and tap until it moves to the right spot.
The max depth of cut is 6" but if you turn the top guides 90 degrees you can get nearly 7". I wouldn't pay £450 for one. Anyone have an opinion on a Startrite 352e at £782 from Hallvalue?
http://www.poolewood.co.uk/acatalog/Sta ... ndsaw.html
Hope this is of some use.
Graham
