Nizz
New member
Ok guys,
So I have had a Startrite 175 saw for a few years, it was given to me and has had some but not a lot of use since I have had it. I'm looking to use it more and want to get it working at its best.
I have a few questions that I'm hoping someone on here will be able to answer or at least point me in the right direction.
Firstly, how can I identify the age of my saw? The serial is 18901
I am also trying to remove play in the fence if possible, when locked in place it's fine but the far side moves around a bit before locked in.
Also with regards to the fence, does someone know the tread of the 2 front and 2 back bolts, I have seen another thread on here about this but not sure if it's been found. I have 2 of the 4 that the heads are pretty wrecked on and would like to replace. I'm pretty stuck in the metric world and haven't really any knowledge on imperial threads other than this is one!
The fence itself isn't perfectly flat - I'm guessing that's why some saws have the wooden fence attached, I'm looking into doing this.
Finally, do you guys have any thing I should do or check to make this saw run at its best, there seems to be a lot of knowledge on this forum on these saws.
Really appreciate any help you can send my way.
