I wouldn't jump out and buy a PT , and a possible cu fusebox upgrade to deal with extracting from it, if i were getting hand planes, may as well use them.
Not to discourage one away from hand tools, lots of stuff to get, just try stay away from high priced stuff and seek out older stuff for cheap when you see a bargain.
One could easily blow it all on silly things like posh aluminium squares.
Just to give a sense of value here's some buy it now's on the bay,
Just trying to give
my preference, for what I'd consider..
These I believe have 1.5kw motors, so that would need be clarified if the single phase one can run of 13a household plug.
The more expensive one would need to be checked to see if it were a dual voltage motor which has 240v stated on the motor nameplate, and then its a hundred quid vfd to buy after that, which will easily run from the household 13a plug, as its the
starting surge of an
induction motor
(as any
machine you get, should be)
which is the most troublesome , and will likely be limited to 2hp/1.5kw if going single phase,
compared to three phase with 240v
dual voltage motor with adjustable soft start via VFD, which is easy on the supply, and worth consideration if a really good bargain shows up locally.
Possibly a bit much to pay compared to the cheaper one, just comparing , and
noting that the fence wouldn't be difficult to make,
however one would question why it were missing in the first place ?
I'd want to see it cutting before consideration. (edit: it does have a fence)
Just sayin what some others have suggested to get one really good thing which suits best,
instead of multiple half working machines with niggles, and methods of which you might consider doing in other ways.
And especially so if you've ever looked at much aluminium tools,
try and acquire a good core machine before you splash out on new stuff unless its good quality and good value.
If you've not looked at the multiple youtube recommendations here before, then it might be good way of finding what work suits you, hand and machine.
Just to even get
a first hand impression of things,
and not form any particular way of thinking which will empty ones wallet
as that is the name of the game for most.
Depends on what your making but for me there's not many folks who's workshop is a similar setup to mine, as in small workshop, dealing with it whilst trying to be productive, even just in a hobby setting.
Easier if it were the size of Rob Cosman's workshop, but I wouldn't be able to afford the overheads.
I'm quite happy using hand planes instead of needing a PT ,
and the only universal motors in the workshop are on a hand drill, and maybe an angle grinder sometime.
No screaming lunchboxes for me, only quiet reliable induction motors,
oh wait I do have some routers in a press, very messy business, I don't use them too often, those can be gotten cheaply, if you keep an eye out.
Good luck.
