Stanley number 8; how long the Sole ?
Cordy
1 Dec 2014
Wigan
On eBay a chap from Bolton is advertising one and gives 18 inches by 3 inches
The photo clearly shows No 8 on the stern and BAILEY at the front
Blood & Gore says it is 24 inches
Are Bailey dimensions usually different to Stanley ?
cordy
Quite correct clk ! =D>
I've emailed and suggested he alters his advert to number 6
I have a nice Stanley 7 and fancy a No 8 for no particular reason
Yep that's a No 6.
I've measured my vintage No 8 and its 605mm x 80mm (just under 24" by 31/8").
Jonny
Hi Cordy. How do you link to an ebay page on your post by using 'here' ?
Jonny
When typing a post in the Full Editor you select (highlight) the text you want to make into a link - 'here' in this example; click the URL button; edit the opening URL tag to add an '=' sign and then insert (copy and paste works best) the link e.g. so that it reads '[url=http://www.ebay.co.uk/itm/13162.... etc. You can see the actual code if you click on Cordy's post using the 'quote' button.
HTH
Quite correct HTH; use full edit so you can Preview your post
type
Here
For example
[url+http://www.panoramio.com/user/8651234/stats]Here[/url]
If you change the +to = it will show the link
Which is
Here
12½ inches long
:mrgreen: :mrgreen: :mrgreen:
Seriously though
Cordy":1gyrurzn said:
Are Bailey dimensions usually different to Stanley?
Stanley make Bailey planes - they're the same brand. However, as the term Bailey is often used to describe the frog arrangement in planes by Stanley's competitors. But in this case it's a Stanley Bailey plane.
Cheers, Vann.
    59.9 KB
    56.7 KB
