Ttrees
Iroko loco!
Well I suppose most of you are thinking quite the opposite!
and are welcome to share their thoughts, but it seems not a bad solution should one feel like splurging on something for themselves.
Bought this just after Christmas at something like 88 quid in euros.
I bought this as I have a bandsaw which I want to setup, and this old aluminium beam was a small bit questionable for the job. mainly concerns about twist.
Smoothing over the sharpish edge of this old square to prep the benchtop
I done the corners not so long ago, obviously didn't foul the long edges of this useful mini blued steel straight edge tool.
The tool is not only for that, but since I've been using my "rough" bench for a while, made of some dense composite counter material (which turned out to be handy for its versatility)
but it's proving to be progressively a bit droopier over the years.
I've gotten used to the topology of the bench, and those high spots which have developed,
the bench can't really be improved upon by shimming, within reason that is,
and I found I could make do with some old door rails in the middle to have it somewhat trustworthy enough to rely on, in combination with methodology
to achieve a gap free match in timbers of a similar length to the bench.
Getting that bench clean of grit isn't as easy as a few brushes down,
this aluminium is either quite soft compared to some other aluminium bits I have, Saying this, not having had experience with a quick deep milled finish,
so it could be simply down to that.
I'll be covering up the edges with tape very soon, hence marking gauge at hand.
Just to be clear this is an incomplete review, and a better look at it will be done in future,
as I'll be properly putting it's accuracy to the test, and doubling the error.
This cannot be done now, as material deflection over something of this length makes a thin benchtop not great for supporting the work to produce accurate results.
I have another bench as long, 4" thick seasoned iroko, which will be flattened at some time, and it should be a good bit more accurate than this counter.
So with that said, a quick inspection of the thing with a critical view.
This is with the bubble side up
The mill patterns are different, not as tangential as on the good side.
Sorry don't have a clear pic of the other good edge, the mill marks are of similar depth and near 90 compared to 45 above.
Both edges seem to have be consistent with very slight crown when something flat is hinged across...
There is some discrepancy of those lips on the face which are also milled, one face side being about 1/64" out when a square is placed against it,
the same when turned back to front, which is at least assuring for this inspection.
Not that I'd be much concerned about that, but just for interests sake.
More to follow on the important stuff.
Tom
Tom
