What thread does a Stanley Cap Iron Screw have? I wonder about getting a couple made up. I tried buying a couple of new one (Clifton and Quangsheng), but the screws are wider (larger dia) than the older Stanley ones.
The cap screw thread is the ONLY standard Whitworth thread on the whole plane....Looks like 5/16-18 Whitworth was what I need. Looks like I should get myself a set of Whitworth taps and dies. If nothing else that will give me a good set of screws to test against.
Can't allow that to go unchallenged !If it helps, you'll find that 5/16"-18 Whitworth and 5/16"-18 UNC are interchangeable for all practical purposes.
You are neglecting to consider the whole story - you quote the Effective Dia for 5/16 UNC only for a Class 3A fit - and even that has a tollerence :-The effective dia. of 5/16" UNC is 0.2764". Effective dia. of 5/16"W is 0.2769". Half a thou difference. The Whitworth thread angle is 55 deg. and UNC 60 deg.,
