Steve Milne
I’m having an issue setting up my Stanley Bailey #5 plane. It is a modern plane, probably from around 2000 or so. It has had no ‘fettling’ done on it.
I am no expert and am just getting back into woodworking after a lengthy hiatus. So it could be something daft that I am doing. But I have been on the old You Tube and am reasonably confident that I am putting it together correctly.
The issue is that the spring cap keeps popping off! I assemble it as I believe I should. The screw sits nicely into the little ‘teardrop’ slot. And it is tightened down so that it snaps solidly into place and I can advance the blade. When I advance the blade it all works as it should. However, when I retract it, the spring cap moves a mm or so upwards (so that the screw is no longer tightly seated in the teardrop slot. After 3 or 4 advance/retracts the spring cap just pops off.
As a comlete beginner I have no idea why it is doing this and therefore I have no idea what I need to do to fix it.
Thanks n anticipation of your assistance.
