phil.p":1rfqhf8m said:
Perhaps this is why the spacers supplied by Richard Burbidge keep the spindles 100mm apart. then cut and fiddle the last one in at the top of the flight. Simples!
Rodders
A 100mm ball must not pass between them - with some turned spindles they would have to be closer spaced than 100mm at the top and bottom.[/quote]
I've just checked my previous posts, I didn't say top and bottom spacing at 100mm apart. In which case you would be correct.
What i did say was the richard Burbidge supplied spacers keep the spindles 100mm apart, as necessary.
Regards Rodders[/quote]
Sorry, I wasn't picking holes in your post, just pointing out that spacing the top and bottom 99mm doesn't mean you haven't a 101mm or more gap.[/quote]
Please accept my apologies,
As this was you're second post regarding the 100mm ball not passing through I felt it (above) was aimed at me,
personally.
Well, I would think that the ready cut spacers were less than 100mm long as you point out.
But taking into consideration, they are fixed at the stair and handrail angle, about 40 degrees, in relation to the spindles at 90 degrees, I'm not clever enough to work out what this length is likely to be!
Any way this is the acceptable to our local Authority as I have done a few, and several lately and all passed.
So the widest gap on the turnings must be 100mm .
On Monday I'm going to measure a Richard Burbidge spacer set, 'cos its got me wondering now!
Thanks and regards Rodders
