Stainless steel flues etc
Jacob
What goes around comes around.
7 Jul 2010
Derbyshire
Am looking at multi-fuel stove plus SS flue to go direct through floor above, ceiling and roof. Seems to be a lot of different suppliers out there.
Any hints, problems, recommendations, suggestions?
Have the exact same set up with my morso stove. Can't help with suppliers, all I can remember is that the double walled flue and brackets to go through joists and roof cost as much as the stove. Also the type of fitting for end of flue needs some thinking about, some types don't work very well in certain positions. The chinamans hat type was useless on ourswe now have one that looks like a H. Also depending on amount of flue above the roof line, you may need some sort of bracing to stop it moving in the wind.
try mi flues in blackpool/lancs, i have used them and they have best value double walled stainless flues with all connections.
they have been moving office and my order was a bit mixed up but they have sorted everything out. They should have settled in now.
They do delivery, £15 if order not over £250 nett which is not bad considering the size of the delivery I got for this.
put M I Flues into google
Check the spec for the stove and the flue, I thought that there would be a margin for error but after burning through two SS flues I now have cast iron for the first 2m or so to get past the extreme heat just above the fire.
Cheers ta. 3m ceiling height so will do plain CI for most of the way
