I have made an item out of pine. Nothing fancy, just something thrown together for utilitarian purposes, for indoor use. To fit in with other stuff it needs to be dark, almost black. My question is how to stain it and how should I finish it?
This is not an heirloom piece. It is unlikely to be required for very long and doesn't need to be too grand, but I do want it to look reasonable. The main thing I am concerned with is how to avoid a blotchy finish. What I have sometimes done with pine is to seal the surface with shellac and then apply a stain. (Or was it a dye? I am not clear on the distinction). That has prevented blotches but it also prevents the stain really soaking in and the resulting colour is lighter than if the stain were applied without the shellac sealer. Since I want a very dark result this time that may not be a good technique for this piece.
I have thought about painting it instead of staining it. That is not impossible if I am unlikely to easily get the result I want any other way.
Any suggestions?
Any suggestions?
