Stigmorgan
Hi guys, I have 2 heavily spalted pieces of silver birch that I think are too far gone to turn, is anyone able to stabilise them and how much would it cost me?
You can become a Supporting Member or just click here to donate.
Yes and yes, it's gone very soft and big chunks get torn out rather than cut, stabilising with resin hardens it so that it doesn't fall apart while turning and finishing.Hi, can you clarify for me what you mean? Firstly, in terms of too far gone, are you saying they are soft?
Secondly, the stabilising.... is that to harden them up?
I'm aware of the process but don't have the equipment or space to put it if I was to buy it all, for now I just want to know what someone would charge for me to send them the 2 pieces I have and do it for me.Check the latest pricing for resin at easy composites. The biggest cost is dependent on how big they are as that will dictate the size of vaccuum pot you need presuming you already have a vacuum pump for veneering.
It can take up to a week of sitting in the chamber before all the moisture is out of the wood and you inject the resin and of course you then have to let it sit for a day to fully absorb it and then bang it in an oven to cure.
My solution with same is to dry it in a microwave oven (if not dry), and then saturate the soft parts with laminating epoxy. That epoxy is like water at room temperature, and will soak in well. When dried, up to a couple of days, it's ready to be turned or worked with, and retains the interesting patterns.Hi guys, I have 2 heavily spalted pieces of silver birch that I think are too far gone to turn, is anyone able to stabilise them and how much would it cost me?
No need for pressure/vacuum pots? If so then this could be an option for me.My solution with same is to dry it in a microwave oven (if not dry), and then saturate the soft parts with laminating epoxy. That epoxy is like water at room temperature, and will soak in well. When dried, up to a couple of days, it's ready to be turned or worked with, and retains the interesting patterns.
For what I need it would be a vacuum pot to pull the air out of the wood then when you release the vacuum the resin is pulled into the voids created by the vacuumI asked before but got no answer......
I would think a vac pot would be better than a pressure pot, as a lot seem to use the press/p on utube.........
I just dont know....
The biggest problem for me and what I would like to do is that the chambers are round cooking pots. I would need a chamber in the shape & size of a trumpet case for the parts I want to work with. admittedly If I could get one I could batch work the parts and be able to fit around 50 at a time in it. With the ability to add dye to the mix it would make some very interesting highlight components in what I make.
I have looked at pressure and vacuum chambers, Ben's worx made an interesting video about using pipe, I guess 100mm stuff looking at the video, but always be careful about overloading and having a safety method in case the thing pops.The biggest problem for me and what I would like to do is that the chambers are round cooking pots. I would need a chamber in the shape & size of a trumpet case for the parts I want to work with. admittedly If I could get one I could batch work the parts and be able to fit around 50 at a time in it. With the ability to add dye to the mix it would make some very interesting highlight components in what I make.
