RinkyDinky
Haven't posted for a while but always read the forum on a daily basis.
I am fortunate enough to have a Festool Kapex mitre saw and have used an excellent method to square the cut.
I accept that this method is probably overkill for cutting wood, but my engineering background always used these methods and i do have a passion for accurate tools!
I have not seen this method discussed on the forum and if it has, i apologise beforehand, but it may help someone.
I always used to check square by butting up an engineers square up against the blade from the fence and adjusting as necessary:
After removing the power to the saw, and locking the blade so it does not rotate, i check the square of the blade to the base, using a Wixey gauge as in the pic:
Next, clamp a square, the bigger the better, this one is 18" against the fence, that lies parallel to the blade.
Then attach a Dial Test Indicator with magnetic base to the blade and adjust it so that it is zeroed at the fence end of the saw:
Then run the head of the saw along the blade towards you, along the square noting the change in reading on the dti.
Mine read just .010" after using the five square method i had used up till now, but i found that using that method, i had varying results and of course, used lots of wood up that could be used for other things.
The adjustment on the Kapex is on the front scale and is achieved by simply undoing this, and moving the head to zero the dti, then re check.
Mine now is reading under .001" over the full travel, that's near enough for me (!)
I would be interested to hear your thoughts and opinions, and hope that i am not missing anything obvious....
I have used a similar method on my table saw and the accuracy have achieved is quite exceptional after a bit of fiddling.
