Wend
Hi folks,
I'd like to make something with accurately placed holes of various sizes, and thought I'd look at what the options are. It sounds like lip-and-spur bits might be a good solution for sizes for which they are available, and another improvement I should definitely make is getting some better bits than the cheap-all-in-one set I got decades ago.
But reading the archives, it sounds like spotting drill bits are another possibility; I believe a 120deg bit for use with your average twist drill. I guess a single 5mm(?) spotting bit would work with pretty much any drill size, as you don't want to actually make a hole as wide as the diameter of the spotting drill anyway, or the edges of the twist bit will hit the edges of the hole before the point hits the bottom.
But when I went looking, I was surprised to not find any brands that I recognise. The sites I found (https://www.cutwel.co.uk/twist-drills/h ... pot-drills, http://www.phantomdrills.co.uk/shop/pro ... drill_bits and https://www.drill-service.co.uk/product ... ng-drills/) all seem to be selling these for cutting non-wood in not-drill-presses.
So I was wondering whether anyone knows whether I'm barking up the wrong alley, or is this worth a punt? And if it is, any brands to favour or avoid? Finally, are the cheap HSS bits fine for wood, or would I be better off with TiN or TiAlN coated, or carbide?
Thanks for any hints
Wend
Wend
