Rob,
Chris Knight did an extensive review of shaves several months ago on these pages. His account will be of great help to you, if you will do an archives search.
As a result of Chris' posting, I bought an LN Boggs shave and could not be more pleased. I also use LN's little bronze shave, modelled on an older Preston shave--it is excellent too, but if I were shopping for one shave it would be the Boggs shave. Have been using it recently to shape tapered legs for a table. Here, the legs were captured between bench dogs. But this shave has great balance for one-handed use when you want to hold the work in one hand and the shave in the other. And it can serve as a very short-base smoothing plane.
It ships with an A2 blade, so if you consider an LN shave you want to be sure your sharpening equipment will handle A2 (see the other on-going thread on this matter). I find A2 will get every bit as sharp as O1, or Japanese steel for that matter, but it matters what you're using to sharpen it.
Wiley
