Ollie78
Hi all.
I have to make 30 odd double glazed sliding sashes to install in a period property. The moulding does not have to be an absolutely spot on accurate copy, as I will be changing all of them to correct the many various unbelievable bodges of the past.
I normally make my sashes using a router table and a CMT sash set, or sometimes individual cutters to get different mouldings.
Mostly though I only make 6 or so at a time.
So I have decided to take a plunge and get a spindle moulder.
My reasoning being that the job is large enough to cover most of the cost and I should be able to speed up production. Also once I have the machine I will be able to use it for many more things in future.
I have been doing a fair bit of googling about, including some useful posts on this very site.
I have been looking at the Record power machine. http://www.recordpower.co.uk/product/sp ... ckage-deal which seems like a good deal at the moment with sliding carriage for tennoning.
Or perhaps the iTech ( looks identical to SIP one) http://www.scosarg.com/new-machines/spi ... -carr.html also looks good deal.
I don`t think the Record has tilting head, but the iTech does. How useful is the tilt mechanism ?
I will probably get little power feed for safety and smooth finish but I am not sure if the beds will need drilling and tapping (not really keen on drilling into a nice new machine bed) or if there is a standard pre drilled pattern for the feeds. ?
I can only use single phase at the moment.
If anyone has any useful knowledge/ advice about either of these machines I would appreciate it. Or of course another machine I have not considered.
Will these machines be powerful enough to mould 50mm rails etc. And tennon 50 to 60mm in one cut or will i need to sneak up on the tennons in a few passes.?
I have been looking on ebay for second hand as well but I don`t see many single phase units on there with much capacity. Also it is nice to have a warranty.
I have discounted the very small 1500w fox/ charnwood ones on the grounds of small tooling capacity and little power.
I have ordered the spindle moulder handbook, and may take a course if I can find one near to me.
All advice most welcome.
Thanks Ollie.
Thanks Ollie.
